Fuel Filter Location? HELP !!!
blkblazer
07-24-2005, 12:41 PM
Where is the fuel filter located? What type of tools do i need to pull it? Do i need to plug the lines when i remove it? and is it easly located/ work on ?
blazer_guy86
07-24-2005, 08:27 PM
I am almost positive that the fuel filter is directly under the driver door on the side of the frame. I think all you will need to take it off is a 9/16" open end wrench.
Cailen
07-24-2005, 09:54 PM
The fuel filter is almost right at the driver's door. You'll need two wrenches, one for the big nut on the filter itself (to stabilize the filter), and another to turn the nut that seals the line in to the filter. Make sure to vent the pressure from your fuel system first by taking off your gas cap. Keep a small bowl nearby as you will lose a little bit of fuel.
rlith
07-25-2005, 09:46 AM
Use nothing but line wrenches as well, especially if there is corrosion, otherwise you're likely to strip the nuts on the line! :nono:
