96 no start probSarsipius 07-23-2005, 05:14 PM ok first let me say hi to all here. have read a lota posts on the site but first time posting i think it is the fuel pump but need to be sure before i drop the coin on a new one cranks fine has 45lbs pressure spark is good compression is at 155 psi so it is good put new CPS sensor in it no help it will start if you put gas in the throttle body i also heard that the spider injection on the CSEFI could be the prob. or no injector pulse could be the prob Thanks in advance if you need more info or i forgot something dont be shy wildcatsua 07-23-2005, 06:11 PM Fuel pressure should be 55-61 with engine off. Need more info. Did it die while driving? Sarsipius 07-23-2005, 06:16 PM ok thanks for specs it did not die it would not rev up at all i kept hiting the gas then it would rev so i put it in low and with luck i was able to get it home then when i shut it down it would not start back up again bty it has the 4.3 sry forgot to put that Sarsipius 08-01-2005, 10:27 PM just incase anyone was wondering the new pump did the trick thanks for the specs good luck on your projects guys BlazerLT 08-03-2005, 05:11 PM Fuel pressure should be 55-61 with engine off. Need more info. Did it die while driving? No, should be 61-66psi when primed. Automotive Network, Inc., Copyright ©2012
