Air Conditioner Problems!! HELP!!!
bake4fsu
07-22-2005, 08:05 PM
My air conditioner is blowing semi-cold on the passenger's side and warm on the driver's side. I have checked the fuses and all seem fine. Could it be a relay switch?
Thanks for the info!
BNaylor
07-22-2005, 11:31 PM
Its an indication you may be low on R134a refrigerant. Check the pressure with a gauge on the low side port. The pressure should correspond to the ambient temperature. I don't have the figures off the top of my head. But I could check my GP service manual for you.
http://i5.photobucket.com/albums/y186/lizzywiz/gtp.jpg
Thrasher CAI, DHP v1.0 PCM,
3.25 SC pulley, CAIT GMAF, Hi-Flow CAT,
u-bend delete, 160 TS, ZZP Stage 1 TB,
TB spacer, MSD 8.5mm wires, Autolite 104s,
Goodyear Gatorback Serp. & SC Belt,
Nitto NT555R Drag Radials
regalfriend
07-22-2005, 11:33 PM
i have had same problem several times...my car has had a leak and every time it gets charged it leaked out a day later....as it lost freon i noticed the drivers side was warmer than the passenger side, and eventually it lost all the freon and both sides got warm....check the pressure of your freon and if needed charge system...if this happens again then you probobly have a leak...if not there may be a problem withe the doors under the dash that control ac or heat....
