1999 chevy blazer no fuell2d2sav 07-21-2005, 04:52 PM been tryin to figure out my fuel issue, i put a text light to the connecter to the fuel pump and got nothing, then is started pumping, disconnected it at the filter and turned the key on to make sure it was pumping and it was, traced the lines up to the intake and took them off and the one was pressureized, but it would barely start and run then die, but there was still pressure, is there a sensor that tells the injectors to release? or could they really be that clogged? BlazerLT 07-25-2005, 12:30 PM check fuel pressure. l2d2sav 07-25-2005, 06:13 PM cant check pressure on a non pumping pump, when it did pump the other day the pressure was fine 1994chevyblazer 07-25-2005, 07:02 PM im having the same problem but mine is a 94 BlazerLT 07-25-2005, 09:49 PM cant check pressure on a non pumping pump, when it did pump the other day the pressure was fine You just said you had fuel coming out of the one line. What was the fuel pressure when you tested it initially? Automotive Network, Inc., Copyright ©2012
