1993 Buick Regal Custom help
Green Fairy
07-21-2005, 02:33 PM
I need some help! My baby was totaled a few months ago and it's just not the same. :( It was my grandmother's car, so I know the history. It now has a salvage title and I'm planning on driving it until it falls apart. nfortunatly it's already started to do that. Here's a list of problems I'm having and if anyone knows how to help me please let me know!
1) Front passanger speaker is blown.
2) Front driver window whistles, and one of the back windows whistle too.
3) Leather seats are torn, but I don't want covers to look tacky.
4) There's a short or something in the driver's door that causes the locks to not work from time to time.
5) When I start my car there's water underneath it, but only after it's been sitting for over 8 hours.
6) Radio antena doesn't go down all the way.
7) Inside of the windows are greasy.
8) Car is stinky, no matter how many times I vaccum it out!
9) Runs really rough sometimes.
Any advise would be great! Thanks so much!!!
y2kpa2
07-23-2005, 11:25 AM
Well most of that sounds easy enough, and i can understand wanting to keep it but, when you say totaled, is it safe to drive? Anyway, The seats could be replaced check your local junk yard,the power antenna,speaker,and door wiring could also be fixed fairly easy. the windows you may want to get a body shop to look at that, the accident may have put the doors out of alignment and get some good glass cleaner and a strong air freshner or replace the carpet. did water get in the car, Rain?
Good luck!
tman
07-23-2005, 11:18 PM
Best option? donate to goodwill!
No, easy fixes for the most part
-Head to a junkyard and get a new speaker
-make sure theyre seating into the rubber gaskets properly by squirting water at the window seams. If they are leaking, remove the door panel and adjust the travel of the windows.
-They make leather repair stuff, not sure where to buy though
Take off the door panel and look for bad wires, and replace all that look faulty, especially in the power door lock circuit.
-might be the AC compressor, not sure how much water youre talking about.
-get some 3 in 1 oil, and lube the antenna in the on position, it should retract fully after a few tries.
-One word: WINDEX
-Get some carpet shampoo, leather cleaner, and leather conditioner. Use some of that windex from problem 7 to clean the dash, but be careful around the white lettering on various plastic pieces. Febreze the headliner and carpet and floormats. Maybe get some leather smellings stuff
-Check your fuel filter, spark plugs, wires, or injectors first, then get back to us.
Green Fairy
07-24-2005, 09:53 PM
I guess I forgot to mention that there was no frame damage. The car is safe. The drivers seat is powered, and the electricity in the door is messed up from when some drunk college student knocked off the side mirror and scraped their car ageinst mine. Windex won't work I tried it. I used rubbing achohol and that worked like a charm though. Thanks to my boyfirend we know that more than likely it's the spark plugs. He couldn't get to them. The car whistled before the accident, there is a screw missing, but I don't know if I can get it a Lowe's. One more thing...The paint on the steering wheel is comming off. Can I repaint it? Thanks guys!
tman
07-24-2005, 10:18 PM
You can buy the steering wheel paint at your GM dealer.
93rgeal87gn
12-01-2005, 09:31 PM
the smell is the front valance leaking under the main carpet or the rear window or door gaskets! mine had the same problem! a dam misty smell so 1 day i took the seats and rug out... evrything was wet underneath then i had my sis spray the car with water found the leak and fixed it!
