Rear Breaksgpdriver21 07-21-2005, 12:50 AM I have changed the front brake pads on my 95 grand Prix with no problems. I went to tackle the rear break pads today and could not compress the piston on the brake caliper using a Clamp. So I pulled the whole caliper off and figured out that the piston just screws in beacause of the emergency brake. During the process of putting the piston back in, I did break the rubber boot off around the piston. By not having this rubber boot on will it cause any problems? Should I buy a new one? Doing the otherside was easy after knowing all i had to do was to screw the piston in to get it to go down, i used some vice grips. GPFred 07-21-2005, 12:42 PM You'll need to change that boot as the tear in it will allow dirt to get into the mechanism which could cause brake failure or lock up. richtazz 07-21-2005, 12:51 PM I agree with GPFred, you need to change that caliper before it seizes. Automotive Network, Inc., Copyright ©2012
