Transmission surging problems?thugmebaby 07-20-2005, 08:53 AM My 99 Blazer will occassionally surge when it shifts gears, I really dont think its surging more like the computer? is not shifting it into gear totally. Its an automatic with only 70000 miles on it. The fluid is just fine and there doesnt seem to be any other issues besides it. It does this when its warm or cold. Could this be a the solenoid? or do I need to replace the transmission? Any help would be greatly appreciated. Thanks DINO55 07-20-2005, 05:06 PM When was the last time you changed your transmission fluid and filter, Dirty fluid and filter will give you Surge/ Shifting problems... thugmebaby 07-20-2005, 08:47 PM as much as I hate to say I have no idea... I bought it used with approx 67000 miles on it. The fluid looks/smells fine but I guess it wouldnt hurt. Should i have them completely flush it also? Would that be the cause though if only does it once in a great while. It appears to be only happening from the shift from 1st to 2nd (start from light and then when it shifts the first time). I always drive it in Overdrive also. btw this is a 99 Blazer LS 4x4 thanks again DINO55 07-20-2005, 09:38 PM Is the ses light on, are there any codes in the computer? DINO55 07-20-2005, 09:44 PM Thugmebaby.... try typing in "transmission solenoid" in the search box....... Allbert 07-21-2005, 11:46 AM It could be the pressure control solenoid or any of good number of other things. If you don't have any way to test the function of the solenoid, you could gamble the price of a new one that it is bad to see if that fixes your problem (they're fairly easy to remove and replace), but since the process normally involved changing your fluid (some of it anyway) and filter, I'd do that first and see if that helps. As far as the whole professional flush thing, I'm not sure it's worth the money. You can get about half or more of your fluid out by driving the truck up on ramps and just removing the pan. In my opinion, that's probably enough fresh fluid to halt any of the poor performance issues that old fluid might cause. The real benefit comes from changing out a potentially clogged filter, which some flush guys may not even do for you. Just be sure you install a new metal-clad seal into the hole that the filter fits up into and clean off your pan magnet real good. Best of luck! thugmebaby 07-21-2005, 08:53 PM The SES light has never came on. I have a computer scanner that can tell me any past codes and it came up clean. As for the transmission solenoid I will look that up as I have no idea how to change it nor where it even is....either way thanks for all the input and ideas. BlazerLT 07-25-2005, 12:20 AM I would service the transmission fluid and filter. Automotive Network, Inc., Copyright ©2012
