Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer
Old 07-18-2005, 01:43 PM   #1
fubarred
fubarred Normal reputation
slight shutter between 900-1300rpms
I am selling my 1997 Tahoe and this problem just popped up. I put some Techron fuel additive in it and it didn't clear up. What could be the possible problems? I have a buyer that wants the truck but wants this problem fixed before buying. PLEASE HELP.
Thanks,
DF
fubarred is offline   Reply With Quote
Old 07-18-2005, 01:45 PM   #2
BlazerLT
AF -Advisor
BlazerLT's Avatar
BlazerLT Normal reputation
Re: slight shutter between 900-1300rpms
MAF dirty,,,,
Tuneup needed?
1995 Factory Blazer Service Manual for sale, PM if interested.
BlazerLT is offline   Reply With Quote
Old 07-18-2005, 01:46 PM   #3
fubarred
Re: Re: slight shutter between 900-1300rpms
Originally Posted by BlazerLT
MAF dirty,,,,
Tuneup needed?
It probably needs a tune-up, or at least plug wires. I changed the fuel filter about 5,000 miles ago.
Old 07-18-2005, 01:59 PM   #4
BlazerLT
AF -Advisor
BlazerLT's Avatar
plug wires are usually the last thing that will need to be replaced.
You know the possible problem now.
Old 07-18-2005, 02:02 PM   #5
fubarred
So I should pull the MAF and squirt it with some brake cleaner? If that doesn't fix it, then break down and do a tune-up? I'm just trying to get this thing sold without dishing out any cash.
Old 07-18-2005, 02:11 PM   #6
BlazerLT
AF -Advisor
BlazerLT's Avatar
Yes, on the back part of the MAF closest to the intake there will be two sensor wires. They might be cruded up.
Ever done a tuneup on it?
Old 07-18-2005, 02:33 PM   #7
fubarred
Nope, I sure haven't.
Old 07-18-2005, 03:57 PM   #8
BlazerLT
AF -Advisor
BlazerLT's Avatar
Then I think you already knew what was wrong before you asked the question in the first place.
You better invest the 50-100 to get it running properly.
No one wants to buy a vehicle that the owner has never properly maintained.
You are lucky he is still even considering buying it now.
Old 07-20-2005, 07:54 AM   #9
fubarred
Well, I've only had the car for about 3 months so it's not like I had it for years and just drove it into the ground. I see your point though.
Okay, I changed the plugs and went ahead and did the wires too. Problem was still there. I took it in to the shop and they said the fan clutch had a lot of play and was causing the vibration. It sounded shady but I went ahead and had them change it out as well as throw a new belt on it. I picked up the truck after the shop closed and the problem was still there. I called a friend that has a scanner and he hooked it up real quick. It's throwing out a code for the rear o2 sensors. I'm going to call around and get some pricing on these today.
This should be a simple project for someone with very limited mechanical skills right?
Old 07-20-2005, 09:53 AM   #10
Allbert
Allbert Normal reputation
Changing a rear O2 sensor shouldn't be too hard, but the rear sensors are only there to verify proper catalyst function... they do not actually affect the fuel system management like the forward O2 sensors do, so a fault in one of these should not be the cause of your shudder.
Allbert is offline   Reply With Quote
Old 07-20-2005, 02:45 PM   #11
xVANx
xVANx Normal reputation
Send a message via AIM to xVANx
my friend had this problem in his '97 jimmy from the sounds of it. he took it to get the tune up on it and that fixed the problem pretty good.
xVANx is offline   Reply With Quote
Old 07-20-2005, 03:32 PM   #12
drdd
drdd's Avatar
drdd Normal reputation
have you cleaned your throttle body?
PCV?
drdd is offline   Reply With Quote
Old 07-20-2005, 03:59 PM   #13
DINO55
DINO55's Avatar
DINO55 Normal reputation
Did you change the Cap and Rotor with the plugs and wires? when my rear 02 sensor went out, my truck would not idle at all...
1998 BLAZER LS Vin-W 4Dr 2wd
2004 Cavalier LS 4Dr 2.2 Ecotec
"Good Part's ain't Cheap--Cheap Parts ain't Good"
DINO55 is offline   Reply With Quote
Old 07-20-2005, 04:12 PM   #14
fubarred
I did not do the cap/rotor yet. The strange thing is that it idles fine but has a vibration/stutter in the certain rpm range. It even has this vibration coming down in the rpm range after you rev it.
Bookmarks
Google
Web AF
