97 Pathfinder / squeaky, squealing
Google
Web AF
MissLori
07-18-2005, 12:41 PM
My pathfinder started squealing a few months ago, it comes and goes and I think it's worse when it's hot outside. Any ideas??
lewisnc100
07-18-2005, 12:58 PM
If its a fairly constant high pitched squeel coming from the front wheels and it doesn't go away when hitting the brakes, it's most likely a noise produced by the hub inner seal against the baffle plate. There is a redesigned baffle plate that eliminates this noise.
If the noise changes goes away or is significantly reduced when applying the brakes then your brakes are probably the source.
MissLori
07-18-2005, 01:14 PM
Thank you for the advice, however; the only time the noise reduces is when I start to slow down; not by pressing the breaks but by letting down on the gas....does this make sense (I do appologize for my lack of mechanical knowledge)
Google
Web AF
