no spark 93 probe
hammer2
07-18-2005, 11:45 AM
it quit running over a year ago. I eventually got around to fixing it and diagnosed a bad ignition control module (which is part of distributor assembly and very $$) I ended up buying one from advance, installed it and it worked. I never used it much but then it started acting funny. Would start but then stall sometimes. I thought maybe a fuel probelm. There was a lot of water in the L rear of car at the fuel inertia switch. I fixed the drain and put in a new switch but the problems persist. The car started one day and ran fine. I used it that day and it started everytime. I went out a few days later and it wouldn't start. I pulled the wires and there is no spark. I started all tests on distributor again and seems fine (crank sensor, cam sensor, coil-all of these are in distributor) So could be ignition control module again or maybe computer? Any suggestion? I posted previously regarding a cheap fix for the ICM but did not get any leads on where to find info.
Thanks
bill
