Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Racing > Non Specific
Old 07-18-2005, 04:27 AM   #1
xXx=BioHazard=xXx
xXx=BioHazard=xXx Normal reputation
Higher octane?
If you would use a boost or spray at all would you pretty much have to use a higher octane gas?
xXx=BioHazard=xXx is offline   Reply With Quote
Old 07-18-2005, 07:57 AM   #2
mason_RsX
mason_RsX's Avatar
mason_RsX Normal reputation
Send a message via MSN to mason_RsX
just spray, im not sure but I would assume so...Boost definately yes, high compression definately yes
but newer engines can have sensors to gague the amount of knock, so if your running low octane gas the engine will read the higher levels of knocking and retard spark timing and lower amount of fuel injected so you will lose alot of performance...and damage to your engine is a major possibility
http://auto.howstuffworks.com/gasoline3.htm
this explains octane and knocking
2002 Acura RSX Type-S
Originally Posted by SiGNAL748
I have an outrageously large penis.
mason_RsX is offline   Reply With Quote
Old 07-18-2005, 06:16 PM   #3
drftk1d
boost in, apex seals out
drftk1d's Avatar
drftk1d Normal reputation
Send a message via AIM to drftk1d
Re: Higher octane?
knock sucks, to avoid it just do 2 things, dont live in california and buy higher octane gas
RX-7 TII
drftk1d is offline   Reply With Quote
Old 07-18-2005, 07:15 PM   #4
-The Stig-
On Fire!
-The Stig-'s Avatar
-The Stig- +350-The Stig- +350-The Stig- +350-The Stig- +350
Send a message via AIM to -The Stig-
Re: Re: Higher octane?
Our cars run just fine on 91 octane.
2008 Pontiac G8 GT - - - - - - - - +1 FTW!
User Guidelines
It's important to read, like the Bible. But unlike the Bible we will strike you down if you jerk off around here.
I watched 3 of your runs and you were handling it man...On that 40 sec. run, I don't if you hit that cone or if it was jet wash...lol
-The Stig- is offline   Reply With Quote
Old 07-18-2005, 07:26 PM   #5
-Josh-
-Josh-'s Avatar
-Josh- +50
Send a message via AIM to -Josh-
Re: Re: Re: Higher octane?
Your standards just suck is all.
Self improvement is masturbation
AF User Guidelines
-Josh- is offline   Reply With Quote
Old 07-19-2005, 01:38 AM   #6
CassiesMan
CassiesMan's Avatar
CassiesMan Normal reputation
Send a message via AIM to CassiesMan
Re: Higher octane?
Pfft, 91? I use 93.
CassiesMan is online now   Reply With Quote
Old 07-19-2005, 11:01 AM   #7
JekylandHyde
AF - Advisor
JekylandHyde's Avatar
JekylandHyde Normal reputation
Re: Higher octane?
Who wants a car that runs "fine" ... I rather have one that runs great
I run 94 octane at the pump here in PA
Seriously though, cars run best on the lowest octane they can get away with without seeing detonation. Octane is a fuels resistance to blowing up ... you want it to explode! That's what makes power. If it is too ready to explode it will ignite when it shouldn't (knock/detonation) so you need a higher oct.
In the 88, the Suburban and Jekyl I run 87 octane.
Hyde, with the turbo, gets the best I can find.
I am almost always running 110 leaded now.
Sponsorship: Amateur Motorsports <-- Get the book! - books are now available for shipment
JekylandHyde is offline   Reply With Quote
Old 07-19-2005, 06:09 PM   #8
nissanfanatic
240SX Guy
nissanfanatic Normal reputation
Send a message via ICQ to nissanfanatic Send a message via AIM to nissanfanatic Send a message via MSN to nissanfanatic Send a message via Yahoo to nissanfanatic
Re: Higher octane?
Fuel octane is as mentioned resistance to the fuel burning. Higher octane fuel burns slower.
I run 9.5:1 CR with 10.5psi of boost on 93 octane everyday. I boost on hot, cold, ect days with no problems. Basically, when you encounter detonation on a certian grade of fuel, you can do these things:
1) Lower the compression ratio
2) Run higher octane fuel
3) Retard timing
4) Cool the intake charge better(AKA alky/water injection)
Water/alky injection is a very good solution to running expensive racing gas while still having the power of it.
And as jekylandhyde was touching on:
IMO you should run a known safe octane fuel/AF ratio and play with timing to get maximum power. BTW, if you end up having to retard timing lower than 20* Total timing BTDC, you should seriously consider #1, #2, or #4 that I listed above. WI/AI is what I would recommend.
We over on the KA-T boards tend to stay away from anything past 18:1 dynamic CR on pump gas. We end up running insanely low total timing and it is just not in any way better to run more boost with less timing.
And on every grade of fuel, there is a knock limit. Or "the maximum and mean cylinder pressures that can be achieved,"
SDSEFI Tech: Pushing it too far.
Very good read on everything engine destruction related.
-Cory
1992 Nissan 240sx KA24DE-Turbo: The Showcar
Stock internals. Daily driven.
12.6@122mph
496whp/436wtq at 25psi
nissanfanatic is offline   Reply With Quote
Old 07-19-2005, 06:10 PM   #9
CBFryman
Banned
CBFryman's Avatar
CBFryman Normal reputation
Send a message via AIM to CBFryman Send a message via Yahoo to CBFryman
Re: Higher octane?
ptshhh.... octane= HP =...duh. thats why i run 93 with NAWZ octane booster in my civic dawg.... i even put some pencil lead in there..
CBFryman is offline   Reply With Quote
Old 07-19-2005, 07:27 PM   #10
-The Stig-
On Fire!
-The Stig-'s Avatar
Re: Higher octane?
Good post nissanfanatic.
Informative... indeed.
User Guidelines
Old 07-19-2005, 08:59 PM   #11
CivRacer95
srs biznis
CivRacer95's Avatar
CivRacer95 Normal reputation
Send a message via AIM to CivRacer95
Shit my secret is out!!
AF Guidelines. Read and play nicely :
Just Click Here!
I Hope you like Pain
blazee = CivRacer95
CivRacer95 is offline   Reply With Quote
Old 07-19-2005, 10:32 PM   #12
nissanfanatic
240SX Guy
Thanks.
-Cory
12.6@122mph
Old 07-20-2005, 03:07 AM   #13
Zgringo
Zgringo Normal reputation
NissanFanatic, You hit the hail right on the head. Very good post, and I'd like to add #5 to it if I may.
For the hard core boost freaks or the ones running big spray numbers, TOLUENE.
With the price of gas, toluene is as cheap as gasoline, and a 4:1 mix we'll make about 98 octane gasoline.
Go to Sherman Williams paint store and ask for toluene paint thinner. It comes from crude oil and is what's used to boost the octane in gasoline by the oil companys.
Also it's legal and will pass fuel tests at the races.
Zgringo is offline   Reply With Quote
Old 07-20-2005, 11:48 AM   #14
-Josh-
-Josh-'s Avatar
-Josh- +50
Re: Higher octane?
So that's what it's come to for you west coasters eh? Having to make your own fuel cause you got nothin but crap....
AF User Guidelines
Old 07-20-2005, 12:26 PM   #15
drftk1d
drftk1d's Avatar
Re: Re: Re: Re: Higher octane?
RX-7 TII
Bookmarks
Google
Web AF
