Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Beretta
Old 07-17-2005, 07:08 PM   #1
catprotector
catprotector Normal reputation
Coolant Leak?
I saw some puddles underneath the car and it looked to be dripping in two places but it appeared that the water traveled down one of the lines to the other side of my car. It has stopped dripping and I guessed it was water because it had no smell or color. It has been very hot here and a little humid so I have been running my car's air conditioner. Could this be a normal part of the overflow? I was not getting a coolant low light nor was the car overheating at all.
catprotector is offline   Reply With Quote
Old 07-18-2005, 09:18 PM   #2
cficare68
cficare68's Avatar
cficare68 Normal reputation
Re: Coolant Leak?
It could be you air conditioner. Keep a check on your coolant If it seems to be getting low for no apparent reason i would investage it it more. But i think it was just the AC which is fine
2001 Fed Spec Mitsubishi Eclipse GT 5 Speed
17" Fittipaldi Rims w/Hanook Tires, Ractive Carbon Fiber Muffler, Debagged, TYC Tail lights, Clear Corners Around, Panasonic 802u, Cadence ZRS10(Mono Block 2500w), 2 Infinity Prefect 12", Custom Fiberglass Box, Polk Momo MMC690 (6x9), Polk Momo MMC650 (6X5), Clarion APA450(4 Channel 400w), Python 900(Car Alarm)
Check me out at http://www.cardomain.com/ride/752720 and tell me what you think!!!!
cficare68 is offline   Reply With Quote
Old 07-18-2005, 09:30 PM   #3
catprotector
Re: Re: Coolant Leak?
Thanks for the reply. It might be low but I checked for leaks today and had no drops on the ground that I could see. I suspect it could have been from the windshield wiper fluid since I did run it yesterday to clean my windshield. The air conditioner is a possibility though as it has been both hot and humid here. Does the air condioner have an overflow valve or some kind of drainage system?
BTW, how does one ad coolant to the air conditioner for a '95 Beretta? I have tried to read the manual but I have no idea where you add the coolant for the air conditioner? Is it on top somewhere underneath the hood?
Old 07-19-2005, 01:23 PM   #4
cficare68
cficare68's Avatar
Re: Coolant Leak?
You don't add coolant to the ac you add Freon, not really sure where that is added at. And if has been hot and humid there that is diffently your probably then. You and cold air cooling down the pipes and where it is hot it is condesating causing it to get moist.
Old 07-19-2005, 02:00 PM   #5
catprotector
You mentioned coolant and I consider freon to be that for air conditioners. I checked my car yesterday and there was no drops on the ground so I guess everything is ok.
Bookmarks
Google
Web AF
