1992 buick regal custom...IN HELP BAD!aphinney 07-17-2005, 07:57 PM well i blew my engine last nite. it is a 3.1l now...i need a new engine. is it poss. to take a 3.8l engine from a bonneville ? or is there anyother car that i can do that in?? need ENGINE BAD AND FAST. thanx alot guys and gals HotZ28 07-17-2005, 11:53 PM Call your local salvage yard. The 3.1 is common to buick, chev, pontiac. GTP Dad 07-18-2005, 06:59 AM Should work but you will need a PCM from the 3.8 as well as a wiring harness. Your transmission should handle it as long as you don't go with a supercharged version. Try cherry-auto.com or car-part.com to help you search for an engine. tman 07-23-2005, 08:38 PM Any of the 91-94 3.8's from GM will mount right in. I'm not sure which tranny the 3.1 has, but the 4T60E is the tranny that the 3800 works with. I'd find a wrecked grand prix or regal GS from 97 or newer, and swap the engine and tranny, you'd have the fastest 92 regal around if you did that. 93rgeal87gn 12-01-2005, 09:33 PM the pcm and engine is all u need! everything else just plugs rite in! i did a swap on my buddies beretta and my 93 regal from a 3800 to a supercharged 3800! tell yea what its crazzzy fast good luck mikelund 12-04-2005, 09:44 PM I hope that since July 17, 2005 he's found a new bad engine fast. Automotive Network, Inc., Copyright ©2012
