Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Astro > M Bodies
Old 07-15-2005, 09:08 AM   #1
james wright
james wright Normal reputation
Angry Engine miss
1994 4.3 all of a sudden runs terrable like running out of gas.
did completet tuneup plugs,wireers cap rotor pcv fuel filter. good fuel pump preasure 14lbs. Rebuilt throtle body new injectors tps switch. did not replace idle air sensor. Runs like it is missing could not isolate one cylinder by removing spark to each one individulely. Good comp but is starting to run hot 210deg. terrable idle worse when under load terribale acceleration.No codes posted on dash (service eng)
james wright is offline   Reply With Quote
Old 07-15-2005, 08:36 PM   #2
CD Smalley
CD Smalley Normal reputation
Re: Engine miss
Is your 4.3 a v6 or v8? I'm thinking it should be a V8. If that is the case, 14lbs of fuel pressure is not even close to enough. Should be somewhere closer to 60psi I believe.
CD Smalley
1991 W41 #142
1995 Astro
1989 Caprice 9C1
1997 C1500
1977-90 GM B-Body email list Owner @ yahoogroups.com
In the recovery room: b-body.org...
CD Smalley is offline   Reply With Quote
Old 07-20-2005, 09:54 AM   #3
james wright
Re: Re: Engine miss
it is a v6 vortec throtle body
Old 07-20-2005, 10:20 AM   #4
CD Smalley
Re: Engine miss
Sorry for my previous post. I was thinking of Caprices at the time.
What's the 8th digit iof your VIN?
Could be several things. EGR valve, plugged cat, etc..
CD Smalley
1991 W41 #142
1995 Astro
1989 Caprice 9C1
1997 C1500
Bookmarks
Google
Web AF
