Grinding noise in front when turningBeaconHill 07-14-2005, 10:51 AM Does anybody know what the problem could be when I hear a grinding like noise when I turn the car. I am about to replace the rotors so I though that may be the problem. The noise appears to come from the front. JTrujillo86 07-14-2005, 06:48 PM Bad rotors don't make noise...if your rotors were bad you would get a pulsation as you brake. That grinding may be bad CV joints. Jeremy dan_f 07-15-2005, 01:21 PM could be the tires, I had two replaced when my car was under warranty, unfortunately i have the noise on the other two now that i have rotated them and it is out of warranty. If it's the same noise i have it almost sounds like a wheel bearing . try rotating the tires first and see if it changes Lazyneko 07-18-2005, 02:12 PM Bad rotors don't make noise...if your rotors were bad you would get a pulsation as you brake. That grinding may be bad CV joints. Jeremy Thanks Jeremy you fixed "one" of my problems.. :D Automotive Network, Inc., Copyright ©2012
