Service Engine Light Error........eld101 07-14-2005, 07:57 AM Got the code read... P1110 Macufacurer Control. Fuel Air Metering What is the likly cause of this in an 01 pathy? lewisnc100 07-14-2005, 08:22 AM Must have gotten that read at Autozone since they gave you the wrong description: P1110 Intake Valve Timing Control, LH Bank Pretty common on that year. eld101 07-14-2005, 08:57 AM Must have gotten that read at Autozone since they gave you the wrong description: P1110 Intake Valve Timing Control, LH Bank Pretty common on that year. what should I figure that will cost me? lewisnc100 07-14-2005, 01:13 PM No idea since my 97 doesn't have that part. You might want to join into the thread below this one on P1135, same sensor just different bank. Axelpkt 07-14-2005, 05:22 PM [QUOTE=lewisnc100]Must have gotten that read at Autozone since they gave you the wrong description: P1110 Intake Valve Timing Control, LH Bank QUOTE] thats what it might be on your 97, but not on a 2001. the code for Intake Valve Timing Control, LH Bank P1140 Axelpkt 07-14-2005, 09:13 PM i just looked in my manual and P1110 doesnt exsist lewisnc100 07-15-2005, 08:18 AM Didn't say it was for my 97 since it doesn't exist for that year. You're confusing P1140 and P1110, completely different errors. Nissan codes are the following: P1110 Intake Valve Timing Control, LH Bank P1135 Intake Valve Timing Control, RH Bank 2 P1140 Intake Valve Timing Control Position Sensor, LH Bank 1 P1145 Intake Valve Timing Control Position Sensor, RH Bank 2 His error is P1110 which does exist for a 2001. There's plenty of posts out there for the same year and error code: http://www.4x4parts.com/ubbthreads/showflat.php?Cat=&Board=UBB6&Number=399318&Forum=All_Forums&Words=P1110&Searchpage=0&Limit=25&Main=399318&Search=true&where=bodysub&Name=&daterange=1&newerval=5&newertype=y&olderval=&oldertype=&bodyprev=#Post399318 http://www.4x4parts.com/ubbthreads/showflat.php?Cat=&Board=UBB6&Number=116497&Forum=All_Forums&Words=P1110&Searchpage=0&Limit=25&Main=116497&Search=true&where=bodysub&Name=&daterange=1&newerval=&newertype=w&olderval=1&oldertype=d&bodyprev=#Post116497 http://www.nissanforums.com/showthread.php?t=97223&highlight=P1110 http://npora.ipbhost.com//index.php?showtopic=2058&st=0&#entry16108 http://www.auto-more.com/detail-1413122.html http://www.infinitihelp.com/Ownership/Common/codes3.htm Automotive Network, Inc., Copyright ©2012
