NEON upstream O2 Sensorfixitman02 07-12-2005, 08:34 PM i have a O2 sensor that keeps going out and it last about 4-5 days before it gives out any ideas that could cause this? palindromelol 07-13-2005, 02:00 AM Pardon my rudeness but are you absolutely certain the O2 sensor has failed and it is not a broken wire to the O2 sensor. I had one of those and I did not check the wires before I replaced the sensor for the first time. A connector was rubbing on the damper of the right drive axel and wore a hole in the insulation an through the wire. This was after a front engine mount failure which allowed the engine to rotate slightly and tug the the wire harness close into the axel. Neat problem. I fixed my O2 sensor problem by replacing my front engine mount. :smile: Automotive Network, Inc., Copyright ©2012
