th700r4 transmission troubles still
ekim2u2
07-12-2005, 07:06 PM
I changed out the trans but still have basically the same trouble.It had a hard shift from 1st to 2nd and all else was fine.Now after changing out the fluid it shifts from 1st to what seems like 3rd and will not shift into overdrive. i tried adjusting the throttle valve cable to no avail.Any suggestions?
Mike
badasstour
10-14-2005, 07:45 PM
is the tv cable broken in the casen or did you check if it is hooked up on the trannyand does it look good
