96 ESI Talon is overheating
Princess Lauren
07-12-2005, 12:59 AM
I was wondering if anyone else had this problem. My car is overheating in 5th gear if I dont have my air duct thing switched to the outside air coming in through the engine. If i turn on my AC it also overheats. I have a newly replaced radiator, new water pump, drained out radiator and filled with water to make sure there were no air pockets and that didnt work. Any suggestions?
l_eclipse_l
07-12-2005, 02:35 AM
1. what air duct thing are you talking about?
2. did you fill the radiator with straight water? you should have mixed in coolant about a 50/50 mixture for the best results.
3. need more information to help
david-b
07-12-2005, 01:29 PM
The air duct thingy is the little switch inside to change if the air coming inside the car is air from the outside or through the cooling/heating system. It's generally not safe to drive with that open for too long.
Fill the radiator with 50/50 water coolant. Make sure there's plenty in the resivoir, and make sure it's not leaking anywhere.
