problem with ignitionBweston85 07-11-2005, 01:33 PM I cant get my key to turn at all, how can i fix this??? bjd088 07-11-2005, 01:37 PM Is the steering wheel locked? Bweston85 07-11-2005, 02:48 PM it seems locked and ive tryed jerking it back and forwth while tryin to turn the key and it wont budge bjd088 07-12-2005, 01:39 PM will the steering wheel move at all, if so, try just moving it a little to take pressure off the locking mechanism then turning the key while holding the wheel, if the ignition is worn out you might need to jiggle the key while turning it. KimMG 07-13-2005, 03:41 AM Have you tried a different key? When the keys are worn, they will no longer work. It is more common for the keys to wear out rather than the locks. In 15 years I have gone through 5 keys. riptide8016 07-27-2005, 02:04 PM I have a similar problem on the 89 p/u that I just bought: I can turn the key to start the truck, however once the key is in the ignition I can't turn it back to the lock position. The only fix has been to disconnect the battery and put it in neutral. This system woks without fail, however .... who wants to do that to turn the truck off? I called my local Toyota service dpt. and they said to check the neutral switch, ignition switch, and brake switch. I'm a do-it-yourself-guy, and I have no idea how to locate, fix or replace any of those parts. Any help or alternative ideas? Automotive Network, Inc., Copyright ©2012
