Engine dies after startingauto trainy 07-11-2005, 05:37 AM 96 soc starts fine then after 6-7 minutes or temp gauge at 1/2 the engine dies and cannot be restarted for 20 minutes,no codes.when trying to restart there is no ignition,any thoughts thanks das2123 07-11-2005, 09:16 AM Could be a faulty thermostat...Check coolant levels and thermostat. This is my first guess. palindromelol 07-11-2005, 07:52 PM Sounds like a temperature dependant/time dependant short circuit in the temperature sensor circuit... here is why...... In the following link, http://www.neon-owners.org/neon/tech/manuals/1997/EPL_TAB.PDF Refer to EPL_8W.PDF Page 8W-30-7 The temperature sensor shares a ground with the cam sensor, the crank position sensor and the battery temp sensor. You might unplug the sensor and see what happens just to confirm the fault. Refer to EPL_7.PDF page 7-7 High gage temperature trouble shoot (not too helpful) Refer to EPL_8E.PDF page 8E-7 Temperature gage test (a side issue) Most importantly: Refer to EPL_8D.PDF page 8D -15 and 16 Engine coolant temperature sensor check/removal and installation (diagrams included) AUTOUSA 11-08-2005, 05:00 PM Sounds like a temperature dependant/time dependant short circuit in the temperature sensor circuit... here is why...... In the following link, http://www.neon-owners.org/neon/tech/manuals/1997/EPL_TAB.PDF Refer to EPL_8W.PDF Page 8W-30-7 The temperature sensor shares a ground with the cam sensor, the crank position sensor and the battery temp sensor. You might unplug the sensor and see what happens just to confirm the fault. Refer to EPL_7.PDF page 7-7 High gage temperature trouble shoot (not too helpful) Refer to EPL_8E.PDF page 8E-7 Temperature gage test (a side issue) Most importantly: Refer to EPL_8D.PDF page 8D -15 and 16 Engine coolant temperature sensor check/removal and installation (diagrams included) Man that is one cool webpage if you need info.....WOW!! :cheers: Automotive Network, Inc., Copyright ©2012
