Run the new engine this weekend...chevytrucks92 07-10-2005, 10:55 PM Well, I found out the difference between a flat top 355 and a flat top 406 this weekend: .388 seconds. My best run Saturday night was 4.791, and my best run this year with the 406 was 4.403. The difference is out of the hole. This motor doesn't have near the torque of the 406. Its like driving a street car out of the hole, but man once it gets some RPMs built up and gets into high gear, its coming on strong. You can hear it winding up, lol. I think part of that is the type converter I run. Its a tight converter and this little 355 just don't have the power to turn it like that 406 did. But, aside from being slow, it done good. I went 3 rounds last night. The car was very consistant. Off the trailer it ran 4.904 but the valves were WAY off and I had a plug wire about ready to come off. We fixed the plug wire and it ran 4.87. After that run, we then adjusted the valves (they were way too tight) and it ran a 4.819. We wound up gettin 4 time runs because the track screwed up the tree in our first run, so my 4th time run, it ran a 4.816 and I cut a perfect reaction time (.500). That gave me the bye run for the 1st round eliminations (best light gets the bye run here) and in that, I dialed a 4.81 and ran 4.818. That was 3 straight 4.81s. In the 2nd round, I raced an S-10 race truck whose driver was bound to be new or just "in bad shape" if you know what I mean. Anyways, he was dialed a 4.99 and cut a .600 light and ran 5.91! I dont know what happened to him. Anyways, I was dialed...you guessed it, 4.81, and cut a .56x light (gave myself some slack with him) and ran 4.870 (got way out of it). In the 3rd round, I got put in the left lane (had been running the right lane becuase most of the fast cars run the left, so they'll put ya in the right anyways) and I had only ran it one time before (4.819) so we dialed a 4.80 and I wound up running 4.791. So I broke out and that lost the race. Anyways, the motor done good considering what it is, and how much car its having to lug around (2700 lbs worth as it sets). And I never realized just how strong that 406 I had was, lol. I think I was seriously under estimating its hp. I always figured on it having 500, but now I think it had more like 550, lol. I figure this enigne makes 425-450 hp or so. Either way, it'll do untill I can either get a set of high compression pistons for it, or get my 406 back in running shape. Cliff Notes -run the new engine, flat top 355 with the heads, intake, and cam from the 406. -went 3 rounds Saturday night, broke out 4.791 on a 4.80 dial -about 4 tenths slower then the 406. -although its slower, it still done pretty good and was very consistant: 3 straight 4.81 runs. -best run was 60': 1.624, 330 ET: 4.791 -Josh- 07-10-2005, 11:32 PM The 406 gonna get rebuilt? chevytrucks92 07-11-2005, 09:39 PM The 406 gonna get rebuilt? Yes sir. I figure there is still 2-3 solid months of racing left and I plan on having it ready sometime before then. It just depends on how good I do with this engine in the meantime. If I get on another roll and win 3 in a row, then I'll just leave it alone untill the season is over and change it this winter. But yeah, the 406 is def. getting overhauled, and if my mind don't change, its going to get a set of dome pistons. I also want to take this 355 and get a new bottom end for it, and it will for sure get dome pistons, probably 13.5:1 or bigger. I'll do that after I get done with the 406. -Josh- 07-11-2005, 10:15 PM Damn, dome pistons at 13.5:1!! The timing on that's gonna be a bitch to set! Igovert500 07-12-2005, 12:21 PM Glad you got Casper up and running again. Good luck chevytrucks92 07-12-2005, 05:44 PM Damn, dome pistons at 13.5:1!! The timing on that's gonna be a bitch to set! Haha. Nahh! Line the dots up on the timing gears, and then set the time revving the engine to about 4 grand and on 40 degrees advance. Adjust the valves on .028 and it makes for one stout engine. We used to have one like that. A 355 with 13.5:1 pistons. It's the engine that ran 6.71 @ 101 mph in the 1/8th mile that I've talked about before. Now we always run 12.5:1 pistons in the 406s (aside from the one that I blowed up, lol), and that's what I'd like to get back for it. My uncle has a 406 with around 12.5:1 pistons in his Vega and it runs 4.0hs in the 330. That same engine ran a best of 4.26 in my car, so you can see there's a significant weight difference in the two cars (over 2 tenths in the 330, lol, imagine if that was an 1/8th or even a 1/4 mile). And I've got better heads then what's on his 406, so if I build mine back with 12.5:1 pistons, then it should be even stouter (should be, but you know engines don't always do what we think they should, lol). Thanks IGovert. -Josh- 07-13-2005, 01:05 PM Haha. Nahh! Line the dots up on the timing gears, and then set the time revving the engine to about 4 grand and on 40 degrees advance. Adjust the valves on .028 and it makes for one stout engine. We used to have one like that. A 355 with 13.5:1 pistons. It's the engine that ran 6.71 @ 101 mph in the 1/8th mile that I've talked about before. Now we always run 12.5:1 pistons in the 406s (aside from the one that I blowed up, lol), and that's what I'd like to get back for it. My uncle has a 406 with around 12.5:1 pistons in his Vega and it runs 4.0hs in the 330. That same engine ran a best of 4.26 in my car, so you can see there's a significant weight difference in the two cars (over 2 tenths in the 330, lol, imagine if that was an 1/8th or even a 1/4 mile). And I've got better heads then what's on his 406, so if I build mine back with 12.5:1 pistons, then it should be even stouter (should be, but you know engines don't always do what we think they should, lol). Thanks IGovert. Yeah, on the drag car we had dome pistons on 11:1 Compression and we had to advance the timing 10*, and adjust the valves to .024 on exhaust and .022 on intake. And i thought that was crazy, i wanna hear a clip of your engine running, i bet that thing sounds mean. :evillol: chevytrucks92 07-13-2005, 05:33 PM It sounds pretty good. Even this 355 with flat top pistons sounds good. It sounds virtually identical to the 406 (and it should, same cam, heads, intake, and headers). You can def. hear the engine turning over, lol. Anyone that's ever heard a big lift cam will instantly know there's one in this engine (its either a .645/.650 or .650/.655 lift roller). Automotive Network, Inc., Copyright ©2012
