please help
atv087
07-10-2005, 07:44 PM
i am going to burn my intrepid its such a pain in the ass first i replaced the ignition switch only to find out i need to replace the multifunction switch because my blinkers stay on and then after i do both of those my ac starts blowing hot the day after What could this be the compressor has the right pressure and the clutch is kicking on but its blowing out nice and hot and i dont need that considering its hot outside
theFREAKnasty82
07-10-2005, 11:47 PM
your blend door, which is inside of your evaporator case is stuck open blending hot air from your heater core to that with your evaporator. To replace, there's usually a vacuum motor mounted underneath the dashboard, you'll have to check your service manual to see which one it is.
Bob Bauman
07-24-2005, 10:44 PM
i would look at the vacuum lines underneath the dash you may have nocked it off
