Rear a/c not workingdh57 07-10-2005, 10:25 AM The rear a/c on my 2000 quit working. The vents blow hot air; however, the front a/c works just fine. Any ideas on what I can check to fix this problem? Temperatures soaring into the 90s, kids are definitely NOT happy!! cdru 07-11-2005, 01:01 AM I'd check the damper that diverts the air between the heater core and the evaporator coil. scyan 07-14-2005, 02:47 PM Where is this damper located ? I have the exact same issue !! Where would you look for that ? I think there is only one ac compressor, so is this in the back ? Thanks ! Scy cdru 07-14-2005, 03:29 PM There is only one compressor. The compressor is in the engine compartment. The evaporator coil, heater core, and blower are all located on the passenger interior rear panel. Automotive Network, Inc., Copyright ©2012
