1994 FORD TOPEX "TEMPO" HOW TO BYPASS AC
Ami
07-09-2005, 02:07 PM
Hi There I Have 1994 Topex The Main Belt Broke One Day So I Thought The Belt Was Old So I Changed It
Couple Of Days Later The New Belt Broke What Can The Problem Be
I Think It Is The Ac It Looks Like It Wobbles A Little Bit
Is There A Way I Can Bypass The Ac Unit Does Anyone Know The Size Of The Belt I Should Buy To Bypass That Ac Unit
williamskinner16
07-13-2005, 05:14 PM
check your idler tension pulley if the bearing wore out it could cause this problem. if the compressor (A/C) is the coulprit you will need a shorter belt or an A/c eliminator kit(rare and hard to find) I dont know of any application guide for eliminating a/c and its not gaurunteed by asking for a new belt for your application without a/c would work(did ford offer that model without A/C?). also look at the belt pattern route and taking away that pully, will this alter the direction of any of the other pulleys? before diving into all of that think about it, maybe you got a defective belt or maybe you had too much tension when installing it.
