Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Astro > M Bodies
Old 07-07-2005, 11:23 PM   #1
yewluvme
yewluvme Normal reputation
Send a message via Yahoo to yewluvme
Electrical problem in 2001 Astro Van
Help! For the last year, my interior lights will not work. I have replaced the fuse, but every time I do, It blows again. Also, my CD player overheats and stops working. The radio will work, but it will not play CD's in hot weather or after being on for a while.
Yesterday, my stereo was flickering on and off as well as the warning lights on my dash. Then my battery went dead. I had the alternator tested, and it is not working. I replaced the alternator within the past couple of years. Is there another electrical problem that could be the cause of all of these problems, or are they separate problems?
I don't want to replace the alternator again if there is something in the electrical system that is actually causing the alternator problems as well as the other problems.
I am a single mom, not wanting to take the van in to a local shop and get ripped off or taken advantage of.
Please advise!!
yewluvme is offline   Reply With Quote
Old 07-11-2005, 12:04 PM   #2
jemch72
jemch72 Normal reputation
Hi, it sound like something is in short, any way, if fuse blow every time dont just replace, You have to find what is blowing the fuse, if interior lights do so, is posible that one of the switch on the doors is making a short, or the wires on the lamps, even a light bulb set wrong can do it, there are many posible things...but for sure you have a short circuit ....
If you can, go step by step, remove the lights fuse, any way you need an alternator....also..I dont know but you said alternator fails often..?? probably the regulator went dead on the alternator since normally the alternator is about 100 amps....so test the batery, and then insulate the lights problem, not runing the car so the alternator dont over charge...and test battery again..if you can, use a amp meter to check amps consuption......if all work ok, then the problem is for sure in the interior lights...now to find it could be as easy as hard...you never know...
jemch72 is offline   Reply With Quote
Old 07-13-2005, 09:09 AM   #3
drew300
drew300 Normal reputation
Alternator: I've had the regulators go when there's a bad ground in the system, like rusty bolts attaching the alternator to the block.
I find intermittent (or continuous) shorts in the electrical system with a lamp replacing the fuse. This will give a visual indication, glowing very bright with the short, glowing dimly when all is right, and off when the load (short) is removed. For the interior lights, a turn signal lamp should work well.
Take a blowen fuse, and wire a lamp across the terminals.
drew300 is offline   Reply With Quote
Bookmarks
Google
Web AF
