air vent probsJoYu 07-07-2005, 09:07 PM Hey, just wondering if you guys could give me some suggestions about what could be wrong here. For some reason I can not select the normal vents for air flow (from ac/heater), I can use the upper (defrost) or lower (heater) settings, but when I switch to the main vents, the air continues to come from whatever setting it was last on. I hear a noise, like it is trying to change, but it doesn't. I took out the radio and stuff from the dash, but I really don't see anything. Could one of you guys with experience with these parts let me know which part needs to be replaced? Any suggestions would be helpfull, thanks (did a search and couldn't find anything, hope I'm not missing a thread) orestes 07-07-2005, 09:09 PM there's got to be some sort of issue with all those controls because my fan blower settings are all wacky like what you are describing. no idea on what it is though. look at my thread 'fan issues' if you want to see whats going on with mine. its very strange. AWDSR20 07-08-2005, 02:27 AM take it apart and LOOK at it, something is loose 4 sure..yeah its a pain but thats the onlly way u can tell for sure... AWDSR20 07-09-2005, 06:16 PM VACUME?! what r u talking bout?... my swich was messed up befor..its the unit that opens and close the vents to direct the air flow 2 the interior. anyways...whatever 240SXSlideStar 07-09-2005, 06:22 PM The controls are actuated by vaccuum lines. ulonggapo 08-25-2005, 08:49 AM The controls are actuated by vaccuum lines. Yeah that's what a mechanic told me about my 89 240sx, unfortunately they couldn't find where the damn vacuum leak is. So my air is stuck on one position and i can't change it. Also, i think its affecting my engine, because i can feel my engine surging when i step on the gas but there's no change on the speed of the car. I had a vaccum leak on my bpt before and after i fixed it both problems went away but it came back again after a couple of months. I'm thinking its another vacuum leak. But I couldn't where it is. Does anybody have a vacuum diagram for an 89 240sx? or does anybody knows how to find vacuum leaks? 240SXSlideStar 08-25-2005, 11:09 AM If when you accelerate your revs go up, but your spee ddoesn't change, you have a slipping clutch. ulonggapo 09-07-2005, 07:51 AM Yahoooooooo!!! Finally fixed my air vent problem. I went ahead and replaced all my vacuum lines thinking that was the problem, as suggested on this thread. It took me weeks to do this coz I can only do a little bit at a time and believe me a lot of those lines are a bitch to get to. But it didn't help a bit. So finally, I ended up taking the dashboard off to get access to the entire air system to trace any vacuum lines connected to the air vent system. And behold... there's no damn vacuum line connected to the air vent controls. The problem was the air vent control motor itself had gone bad that's why it was stuck in one position. As soon as I replaced it, it started working. It was a waste of time replacing all those vacuum lines. If only I had the right information :banghead: R.W.240 09-07-2005, 03:07 PM The controls are actuated by vaccuum lines. Uhhh No. all the controls on 240SX are cable controlled. Bwhaha I just read he replaced all the vacuum lines to fix his AC. Old School Domesic Knoledge - FAILED 240SXSlideStar 09-07-2005, 06:35 PM Yeah, I thought it to since alot of cars have that. ulonggapo 09-08-2005, 03:40 PM also man, you could have tested your vacume system without having to just jump ahead and change every hose, that was kind of half cocked on your part. Well I did asked if anybody knew how to find vacuum leaks, and not too many sixteen year olds like me would know. I asked local auto stores if they have something to check it out with or if they know how, and nobody seems to know except check all the lines. If you only had shared us the information before hand instead of blaming me, I wouldn't have to do what I did. So YOU are the half cocked not me. You didn't even give half the information, you gave shitty bullshit info. You were so sure, when you said it was vacuum. APOLOGY ACCEPTED though. Next time, if you are not sure just say it. This place is suppose to be for sharing information to help other people not to be mocked when a mistake was made. Well its good that its posted now so that other people doesn't have to go through what I have to. Since it seems like you are all knowing, why don't you grace us with some of your infinite automotive knowledge and let us know how to check for vacuum leaks. And by the way it's spelled as "VACUUM" not "vacume" :loser: R.W.240 09-08-2005, 04:52 PM :rofl: That is All slideways... 09-08-2005, 06:28 PM shit i couldnt stop laughing. mr. i-know-it-all-cuz-i-work-in-a-shop-and-no-one-else-does just got fucking done drrty by a 16yr old with minimal experience http://files.automotiveforums.com/gallery/watermark.php?file=/500/293248owned-honda.jpg ulonggapo 09-09-2005, 07:34 AM The controls are actuated by vaccuum lines. Uhhh No. all the controls on 240SX are cable controlled. Bwhaha I just read he replaced all the vacuum lines to fix his AC. Old School Domesic Knoledge - FAILED Your another moron, see how fucked up you people are. Giving wrong information just so you can laugh at them. I'm pretty sure you did that intentionally because you didn't know anything about cars. You were trying to make people think you know a lot about cars when in fact you don't know shit. :loser: Also I don't have a problem on my ac its the vents that I have a problem. Read on you moron. :screwy: Like SR20 said and I'll say it to you "that's half cocked on your part." :loser: BWAHAHAHAHAHAHAHA :nono: AWDSR20 09-09-2005, 06:16 PM Your another moron, see how fucked up you people are. Giving wrong information just so you can laugh at them. I'm pretty sure you did that intentionally because you didn't know anything about cars. You were trying to make people think you know a lot about cars when in fact you don't know shit. :loser: Also I don't have a problem on my ac its the vents that I have a problem. Read on you moron. :screwy: Like SR20 said and I'll say it to you "that's half cocked on your part." :loser: BWAHAHAHAHAHAHAHA :nono: u know that there r MODZ in ds forum...right? calm down !!!! R.W.240 09-09-2005, 07:10 PM Your another moron, see how fucked up you people are. Giving wrong information just so you can laugh at them. I'm pretty sure you did that intentionally because you didn't know anything about cars. You were trying to make people think you know a lot about cars when in fact you don't know shit. :loser: : YOU ARE A DUMB BITCH! Read the post agian jackass I was correcting Slide Star. so you not only had to completly misread that entire thing, then you had to change the names on the fuckin qoutes For a second I though you might be a competent noob. Nope. BAN FOR BEING A TOOLBAG. SR20Power Redemed - this kid deserved whatever he got. ulonggapo 09-13-2005, 01:22 PM YOU ARE A DUMB BITCH! Read the post agian jackass I was correcting Slide Star. so you not only had to completly misread that entire thing, then you had to change the names on the fuckin qoutes For a second I though you might be a competent noob. Nope. BAN FOR BEING A TOOLBAG. SR20Power Redemed - this kid deserved whatever he got. my bad, sorry about that...... Automotive Network, Inc., Copyright ©2012
