Brake Light help
rjmonte96
07-07-2005, 03:34 PM
Hi.
I have a 96 Monte Carlo z34 and just yesterday my brake lights went out. i replaced the bulbs but no luck.
The wierd thing is when i turn the hazards on and turn signal on they will light up it is only when i press the brake pedal that they will not turn on
any help you guys can give me will be greatly appreciated.
Thanks
mikiontario
07-14-2005, 01:20 PM
Hi,
I have the same problem with my 95 montecarlo,
the turn signal works, flashers work, but no brake lights, or intermitten brake lights
try lifting up a little on the turn signal lever while applying the brakes, this should get the brake lights to come on,
to fix may need a new turn signal lever or maybe a elastic band to hold the lever up a little.
have a day, ..... Mike
walter17
07-23-2005, 08:32 AM
I would replace the multi function switch. ( turn signal switch )
They are famous for failing, happens all the time.
Just did one three weeks ago.
Brake lights are tied into that same circuit and they all run through the signal switch.
