gas tank for 01 sebring lxi01sebring 07-06-2005, 05:38 PM Help!!!!! Please!!!! I'm at my wits end. I have a massive hole in my gas tank and can't seem to find a way to repair it or a compatible tank to replace it with, any suggestions? Cost is an issue if that helps. das2123 07-07-2005, 09:14 AM Have you tried JB weld? It won't be a permanent fix, but it should hold for awhile. Try hitting up a junkyard for a cheap replacement. 01sebring 07-08-2005, 09:11 PM Thanks for the advise. We've tried JB Weld (multiple times now) and the gas is still leaking from the tank . I guess then the junk yards are going to be my next route. Are you aware of any vehicles that are compatible with this car? Trying to find a tank for this car has car via the internet has been virtually impossible so I'm concerned of the same problems off of the net. das2123 07-09-2005, 10:47 AM The Dodge Avenger is bascially the same engine, so they have similiar parts. I don't know if the gas tank is one of them though. Good luck. theFREAKnasty82 07-11-2005, 01:34 AM actually, in 2001, the sebring was designed, and a fuel tank out of a Dodge Stratus will work, if you can find on out of a junkyard. If I'm not mistaken, that fuel tank is plastic, how did you JBweld a plastic tank? Automotive Network, Inc., Copyright ©2012
