Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Volkswagen > GTI
Old 07-05-2005, 10:08 PM   #1
=loki=
=loki= Normal reputation
Question VR6 Coolant Temperature HELP?!
Hi, I have a '97 Jetta VR6 engine swapped into a '95 GTi.
I have a performance chip and pulleys.
The heater core has been replaced recently after it had blown up.
Just recently, the coolant light has been coming on and blinking after about 1/2 hour of driving. (goes away when car cools a little)
The temperature gauge does not change from normal driving temperature, even when I drive it a little hard with the coolant light blinking. (I guess air cooling is good enough)
The coolant hoses seem to be a little hotter than normal (hard to remember how hot they used to be). The reservior is highly pressurized when I stop to check it after the coolant light has been blinking. When I get the reservoir cap off when its hot, the valve on the side of the reservoir shoots coolant out.
The car does not seem to have any less power than it normally does.
I put my ear close to the area where the pumps are (engine running) and there does seem to be some wirring sounds where the pump(s) are, but again, I'm not sure how normal this is since I don't normally have to cram my head in the engine bay while its running.
Anyone have some suggestions as to steps I can take to remedy the problem?
So far I've been thinking of getting the system flushed and if that doesn't work I was thinking of taking it to my mechanic to test the temperature sensor, then pump(s).
Any help would be greatly appreciated.
=loki= is offline   Reply With Quote
Old 07-07-2005, 11:08 AM   #2
G-man422
G-man422's Avatar
G-man422 Normal reputation
Things like that are best left to a mechanic, cause sometimes if youre not sure whats going on and try to fix it youreselfe you screw it up more.
It sounds a bit tricky.
G-man422 is offline   Reply With Quote
Old 07-10-2005, 02:09 AM   #3
PepeLuche
PepeLuche Normal reputation
Re: VR6 Coolant Temperature HELP?!
Probably you should try the guys on the Vortex, i don't know much about those VR6, i'ma mk2 guy. AF is good for Chevys and Fords but Vw help lacks. No offense to nobody. www.vwvortex.com ---> forums.
PepeLuche is offline   Reply With Quote
Old 07-12-2005, 10:02 PM   #4
veedubmechanic
VDUBMAN
veedubmechanic's Avatar
veedubmechanic Normal reputation
Sounds like a stuck thermostat (common problem on vr6) Its in the housing with all the coolant sensors.
ASE and VW certified. Just here to help
all check light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
veedubmechanic is offline   Reply With Quote
Bookmarks
Google
Web AF
