compression numbersrushb18 07-05-2005, 08:19 PM Well its been a while since ive been on AF used to be over in the EG 92-95 section..Now got a Ek and need some info no one seems to know in EK section I got a 98 civic cx hatch and was wondering what the compression should be at...I did the check on it the motor is strong and all just wondering if my compression is still close to factory or if i should go on and do a engine swap in it... I did search in forums and stuff didnt see anything that shows the numbers of what compression should be at... So if anyone can help me out and lead me to a site or somethign that will show hondas compression specs it would be a big help... Thanks later illegal_eagle187 07-07-2005, 02:22 AM correct me if im wrong i believe 9.2:1 rushb18 07-07-2005, 04:51 AM No im talking like compression for each cylinder like 170 and so on across the board....Ive checked a few forums but really couldnt find nothing on it...I guess ill have to check with autozone and all to see.. Thanks for your reply anyways...later snowman2005 07-07-2005, 07:45 PM should be around 180 +-25psi i belive jcrx 07-08-2005, 04:14 AM should be around 180 +-25psi i belive Close 185 is nominal and 135 minimum with a variation of 28psi :) snowman2005 07-08-2005, 10:31 AM thanxs for corecting jcrx 07-08-2005, 10:54 AM Hell, if you guessed off the top of your head, that's close enough for me. rushb18 07-08-2005, 03:08 PM Ok thanks for the info guy...Later Automotive Network, Inc., Copyright ©2012
