oil on spark plugsRSKBDK 07-04-2005, 09:16 PM i noticed when taking out the spark plugs that they were covered in oil , and when i removed them the oil ran into the cylinders . . . i assume the valve cover gasket is shot , is this correct or could it be something else ? ? ? ? also i need a new a/c compressor any idea's ? ? ? ? for a 92 sl2 autotranny r134a . . . thanks bob cbeck 07-04-2005, 09:40 PM I agree that it is likely the valve cover gasket, a fairly common problem. I've got nothing on the A/C sierrap615 07-06-2005, 01:33 AM valve cover gasket the 92 came with R-12, you could get a R-12 compressor and keep R-12 or retrofit or get a R-134a compressor and retrofit. oldmanwalking 07-08-2005, 08:37 AM definetly valve cover gasket.. pretty easy to fix. If you need to change the compressor THIS would be the time to get an r134a one, new accumulator and fittings, In the long run you'll be much better off, Phil travelair 07-11-2005, 09:22 PM Listen to the valve cover advice. I had trouble believing mine was the source of the leak but it was. It had hardened and was brittle from the heat. The new one was soft and pliable and it hasn't leaked a drop since. It is an easy repair just be careful to tighten the bolts evenly and do not overtighten. RSKBDK 07-20-2005, 10:03 PM thanks for all the advice , the gasket and plugs are changed and i'm waiting for the rebuilt compressor from texas to come , the car was retrofit to r134a by a saturn dealer before i got it . . . thanks again bob Automotive Network, Inc., Copyright ©2012
