95 neon hard to startStealth_SUX_ 07-04-2005, 02:11 PM Hey I have a 95 neon and it will turn over and start but only if u step on the gas at the start, then it will stay on. But if u do not touch the gas then the car will die right after u start it. all hoses checked, everything checks out, any help would be great thanx das2123 07-04-2005, 07:57 PM Could be your EGR valve sticking on you. You can pull it out and try cleaning with something like WD-40, you can replace it, or you can block it off. A new one from the dealer will run you around $80-$90. Automotive Network, Inc., Copyright ©2012
