Mini me head swap?
hesser414
07-03-2005, 07:17 PM
I am currently wanting to put a d16z6 head onto my d15b7 block. I know this can be done as I have it seen it many times. Does any one know where I can find a complete write up on this swap? Also, does anyone know how had it would be to add a D16y8 intake manifold? I hear this is the "Type R" manifold of the D series. Should I change the throttle body to a d16 throttle body, or are they the same as a d15? Fuel injectors? Any help or comments would be appreciated!
Holla!
QUICK_EG_B16A
07-18-2005, 04:58 AM
Not To Discorage You But Your Better Of Doing A Full Swap. I Did The B16a And Love It. Unless You Plan On Doing It Yourself It Will More Than Likely Cheaper Too. when i was considering doing the same thing i found that in ca at least it's illegal (for smog at least) and the full swap was only 1000 more (installed).
unleashedxbeast
11-25-2005, 03:07 AM
Not To Discorage You either but the d16y8 manifold is not a type R manifold. it is like a mini type R .meaning it works a little like it.read about before. Its better to just get a d16 block instead of trying to put a d16 head on a d15 block.your gona get more out of a d16block with d16 head trust me. try getting a vtech head for ur d15 block if u dont want to spend a lot.
