Stock Bov Question
aking3000gt
07-01-2005, 05:29 PM
alright guys my friend has a srt-4 we need to kno how to remove the stock bov.... he bout a egr plate also so can anyone tell me how to intall it and remove the bov?
thanks
TEXSRT4
07-01-2005, 10:02 PM
the factory surge valve is located immediatly undernieth the turbo itself. there are 3 10mm bolts holding it on. egr plate? are you refering to the block off plate, by AGP, for the turbo? if so, you simply bolt that on, the same way you remove the surge valve. just be sure you have another blow off valve that your going to run. you will need to replace your factory up-pipe (between the IC and the throttle body) with a hard pipe with a BOV flange. bolt up the BOV, and run the vacuum lines! DONT RUN THE CAR WITHOUT A BOV, IT WILL CAUSE TURBO DAMAGE
