Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Mitsubishi > 3000GT/Stealth
Old 07-01-2005, 03:12 PM   #1
Wischmaster
Wischmaster's Avatar
Wischmaster Normal reputation
Screws!
Yeah, I have a sort of different question. Do you guys ever come across those screws that just won't turn... but you don't want to strip them. How do you get them out?
I was taking my headlamps out but I ran into two little screws that hold it in... and they wouldn't turn for the life of me. They we about to start stripping so I stopped. They are not rusted or anything. Hell, the rusted one came out easier than these ones. Is there any sort of chemical or other method to use?
Thanks.
Wischmaster is offline   Reply With Quote
Old 07-01-2005, 04:48 PM   #2
Linebckr49
Linebckr49's Avatar
Linebckr49 Normal reputation
Send a message via AIM to Linebckr49
Re: Screws!
elbow grease
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Linebckr49 is offline   Reply With Quote
Old 07-01-2005, 06:18 PM   #3
Wischmaster
Then how does one get out stripped screws?
Old 07-01-2005, 08:37 PM   #4
Hotshot8792
Hotshot8792 Normal reputation
Re: Screws!
crap, stripped screws are boogers. You can probably get a stripped screw out the same way you can get a stripped bolt out. Get a small drill bit, drill a small hole in the center of it, then get an easy out, put the easy out in the hole you drilled and screw it out.
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
Hotshot8792 is offline   Reply With Quote
Old 07-01-2005, 09:48 PM   #5
Twizted_3KGT
Twizted_3KGT's Avatar
Twizted_3KGT Normal reputation
Re: Screws!
Spray the hell out of it with some PB Blaster or Liquid Wrench, let that set for a long while and try again. Are you talking about headlights or fog lights? cuz the fog lights have screws and the headlights have 2 bolts. My fog light screws stripped so bad I had 3 mechanics try all sorts of methods, ended up buying some aftermarket lights.
1997 Mitsubishi 3000GT VR4 - 269AWHP/290AWTQ (Mustang Dyno) - 12.616@106.74 - 1.756 60ft. - 8.06@83.59 - Stillen Downpipe - ICH 3" Single-shot Catback - Gutted Rear Precat - K&N FIPK - IPO MBC @ 15psi - Greddy Type-S - eBay Y-pipe - Maximal Performance Solid Motor Mounts - XTD Stage 3 6-Puck Clutch - 19-Row Upgraded Oil Cooler Kit - Intrax Lowering Springs - Polished Aluminum Saleens - '99 Rear Garnish - Driver Mod
Twizted_3KGT is offline   Reply With Quote
Old 07-02-2005, 03:07 AM   #6
Wischmaster
I'm refering to the headlamps themselves. It looks like there are two small screws on top and two on the bottom. Then there are the two level adjustment screws on the top and side. But the thing is, they look new. I got the rusty screw out (of all things) but the shiney ones won't turn. The screwdriver started to turn so I stopped before it was about to start stripping. If the liquid wrench doesn't work... I might try the drill idea. Things like these just make me mad. I wish it was a bolt instead of a screw.
Old 07-03-2005, 03:02 AM   #7
Wischmaster
Ok, tried the drill. That sucked, stripped the screw. I don't know how I'm going to get the screw out now. I guess I could try vice-grips or something like that. *sighs*
Bookmarks
Google
Web AF
