86 toyota pickup, clutch swap, questionsjboatman333 06-30-2005, 10:28 PM So recently the clutch in my truck went out. I really can't afford to have it fixed by a pro and I don't really feel like my truck is worth as much as what it would cost. So I have decided to do it myself. I have a moderate amount of automotive knowlegde, but i definately have a few questions, and if worse comes to worse I can always call my mechanic friend and he will help me out. So to start off I am going to be working shadetree style, using ramps to raise my truck. I assume i need to pull the whole transmission. I figure if i can get it off putting it back on will be a little less difficult. 1st ? - Do i disconnect the drive shaft, if so how does it come apart? 2nd? - Do you think i will need any specialty tools that i might not have? 3rd? - Once i have unbolted the trans from the engine, and removed the tranny mounts, will there be anything else i need to remove in order to pull the tranny. 4th? - Once the tranny is free, and i plan on using a jack to lower it down, Should i watch out for pieces of the trans falling out or will it be pretty self contained. 5th? - Is there any type of lubrication needed for the clutch that has to filled once the new one is in. Any other tips of suggestion would be really appreciated. I have faith in myself to get this job done, I just need to ask a few questions and get some honest anwsers. I really don't wanna have to call my friend because he works on cars 40hrs. a week and i feel horrible when i have to ask him to make time for me when he is off. One more Question-Do you guys consider jack stand or the ramps to be more stable, I worry about the truck falling on me . Thanks a million, John from nashville ECVcrawltoy711 07-01-2005, 02:00 AM . 1st ? - Do i disconnect the drive shaft, if so how does it come apart? Yes, is it 4wd? 2nd? - Do you think i will need any specialty tools that i might not have? Long extention to get the top t tranny bolts, prolly an impact gun to get the fly wheel off and a pilot being puller 3rd? - Once i have unbolted the trans from the engine, and removed the tranny mounts, will there be anything else i need to remove in order to pull the tranny. shifters and a few wires 4th? - Once the tranny is free, and i plan on using a jack to lower it down, Should i watch out for pieces of the trans falling out or will it be pretty self contained. Should all be good to go 5th? - Is there any type of lubrication needed for the clutch that has to filled once the new one is in. Other then the fluid for the hudro clutch no. also check the rear main also if its leakin replace it DRew jboatman333 07-01-2005, 10:17 AM How do i get the u joint apart? I'm talking about the point where the shaft meet the transmission. BTW my truck is a 2WD. Thanks for the tips! jboatman333 07-01-2005, 12:54 PM I just got a Chilton Manual, it says i need to drain all the engine coolant before i pull the tranny, is this neccasery? Austin8214 07-01-2005, 01:00 PM I just got a Chilton Manual, it says i need to drain all the engine coolant before i pull the tranny, is this neccasery? I do not see any reason to drain the coolant. you will also need a clutch alinement tool to aline the new clutch plate before you tighten down the pressure plate. ECVcrawltoy711 07-01-2005, 01:32 PM How do i get the u joint apart? I'm talking about the point where the shaft meet the transmission. BTW my truck is a 2WD. Thanks for the tips! i wanna say that the 2wd have a slip yoke. it pulls out of the tranny oh yeah have a bucket to ctach the oil. the rear axle has 4 bolts that hold the flange on. as far as draining teh coolent i dont see why u need to unless a bolt goes into a coolent pasage DRew jboatman333 07-01-2005, 03:09 PM Should i drain the tranny fluid? Austin8214 07-01-2005, 04:12 PM I would then you can start fresh. jboatman333 07-01-2005, 07:37 PM anyone got any tips on removing the top 2 tranny bolts.Man i really need an impact wrench!! Austin8214 07-02-2005, 05:36 AM 1/2" drive rachet and a long extention and maybe a universial. mississippiman 11-19-2005, 09:27 PM i seem to be in the same position that you are in, any advice? Automotive Network, Inc., Copyright ©2012
