how to fix ABS sensor
blackhawk141
06-30-2005, 12:48 PM
I've read most of the posts about ABS and traction light but how do you fix the problem? Don't want to pay a mechanic if I can do it myself.
Any help would be greatly appreciated!!!
Little info ABS light and traction off light are on all the time. At first they came on and then went off, now are on all the time. ABS brakes aren't working either.
skibum1111
06-30-2005, 06:43 PM
First, find someone to read the computer and pull the abs codes, I'm not sure if autozone will do abs or not. It could be many things causing this to happen, on mine I have had to change both front harnesses, and the modulator valve got stuck on the abs pump. When it is diagnosed it will tell you more specifically what the problem is, let us know and someone out there will probably have had the problem before....
civilian24
07-06-2005, 04:30 PM
Gonna have to replace your sensor...i'va had the same problem ...the only thing is it cost about 350 for it CND. + the work ...went to the dealership with the same problem
bcopeland
07-17-2005, 07:46 PM
Fix your ABS module for $99 try http://www.modulemaster.com/ because it worked for me it may work for you.
