93 jgc 4wd-6cyl-still wont start-HELP PLEASE
mjsjeep
06-30-2005, 10:55 AM
I posted about replacing the following on my jeep, THIS WEEK: crank and cam position sensors, ignition coil, alternator, complete tune up.
It still won't start. after the IC was replaced it fired once and gurgled in the engine and died. It was flooded, so I replaced the plugs after blowing out the excess fuel. The fuel pump works (tests at 40 pounds). What do I do next??? I am at a loss here. Please help me.
Thanks.
Dale Aeppli
06-30-2005, 11:25 AM
Thanks.
Have you checked to see if you have spark at coil and at the plugs. what do you mean by the ic was replaced. any info. will be of help. dale jeepman600@sbcglobal.net :2cents: :disappoin
mjsjeep
06-30-2005, 02:20 PM
The IC is the ignition coil. And the plugs are getting sparks. I just don't know what to do.
dksob81
06-30-2005, 02:58 PM
well the nxt thing would be air. try holding the pedal down a lil bit and see if it start, you might want to pull the Fuel Pump relay and try starting it a coupl etimes, it might still be flooded, after a few cranks it should start and will run for a second or 2 then die again just do this a couple times and reinsert the Fuel Pump relay, prime the lines (turn key to the ON position) and try to restart the engine.
mjsjeep
06-30-2005, 03:20 PM
Yep. Did that too. It wouldn't go. I pulled the plugs out and cranked just to push some of the excess fuel out. The put them back and still nothing. Someone told me the rings might need a drop or two of oil in the plug holes to lube them up again, it that a good or bad idea?
Thanks
dksob81
06-30-2005, 05:00 PM
is not a bad idea, you could put a table spoon of oil in each cylinder hole (thru the spark plug holes). I doubt if that is going to do anything tho, but it just might.
The engine does crank (turn over), right?
gunjes
06-30-2005, 07:56 PM
Are you sure the cam is turning?
corebuyer
07-30-2005, 04:05 PM
i recently purchased a 1993 grand cherokee
that a rat had chewed the wiring to pieces
replaced everything i could think of no help
somebody befor me replaced the battery cable and did not attach the little groud wire from the cable
grounded the wire and runs like a new one
:):) always check the obvoius first :):):)
