rough idle in the beginnigStrong318 06-29-2005, 11:10 PM When I start the truck up in the morning or let in sit for about 8 hours, when I I start it up it idles rough then revs up and is steady from there on. And it will only do this if like I said let it sit for a while. I have: New plugs New Wires Cat back Headers 180 thermostat K&N system new valve cover gaskets I'm thinking a misfire or something. BleedDodge 06-29-2005, 11:32 PM An older truck? Strong318 06-29-2005, 11:35 PM It is 2001 ram 1500. with 94K on it. 5spd BleedDodge 06-30-2005, 05:58 PM I guess it's a gas engine since you mentioned plugs, and headers. Six cylinder? Strong318 06-30-2005, 07:02 PM It's a 318 V-8, fuel injected crazys182003 06-30-2005, 08:20 PM AH......have you checked with a dodge dealer as to if the computer has been upgraded? I have a similar problem in my RAM which is also the 5 spd. 5.2L. Mine only shows up real abd during the winter and colder months. BUT I am having ti fixed in a few weeks so I will be set and the problem will be solved. NOTE: By doing the upgrade the shift indicator light will not be functional. My indicator light works that is how I know it has not been upgraded. Here is the link for the TSB on it. http://dodgeram.info/tsb/2002/18-011-02.htm Strong318 06-30-2005, 09:48 PM I do appreicate the info and will give it a try. My shift light does come on still so my has not been flashed either. THANKS Automotive Network, Inc., Copyright ©2012
