Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Nonspecific
Old 06-25-2005, 07:58 AM   #1
usalabs
usalabs Normal reputation
1984 celebrity ECM problem? 'maybe'?
After checking the error code from the diagnostics, I found the ECM was not recieving a signal from the ignition module, but the engine runs, sort of smooth, does that mean, if the ECM is not recieving it's signals from the ignition module, the carburettor is not being controlled properly by the ECM, and the running of the engine is affected to the point that when gas is applied slowly (as if pulling away) the engine sort of 'chokes'?, even though the choke flap is open, the fuel filter has been replaced, the carburettor has been disassembled, cleaned, and re-assemled, distributor cap, rotor, leads, and spark plugs replaced.
usalabs is offline   Reply With Quote
Old 06-26-2005, 09:26 AM   #2
84fiero123
84fiero123's Avatar
84fiero123 Normal reputation
Re: 1984 celebrity ECM problem? 'maybe'?
when the ecm doesnt recieve codes it goes back to the defalt mode and runs everything at startup mode. that could explane why it seems to be running rich, sounds like it. it could be a bad sensor in carb, or somewhere else, being as old as it is you should be able to pick up a yard computer cheep enuf if thats the problem, but i dont think it is. i think you have a bad sensor,
which one is guys? any help here?
technology is great when it works
but one big pain in the ass when it doesn't
Detroit Iron Rules, all the rest are just toys!
84fiero123 is offline   Reply With Quote
Bookmarks
Google
Web AF
