A/T problem??grey16 04-20-2002, 09:01 PM I have a 95' 4 runner limited sr5 with the 3.0L. when i drive for about 40 miles i get a A/T hot light on my dash. then i have to pull over and there is usally some fluid flowing over the over flow. does anyone else have this problem? and what was the problem and how much was it to fix if anyone can help please. thanks wfjohnsonjr 02-18-2004, 06:24 PM I have a 95' 4 runner limited sr5 with the 3.0L. when i drive for about 40 miles i get a A/T hot light on my dash. then i have to pull over and there is usally some fluid flowing over the over flow. does anyone else have this problem? and what was the problem and how much was it to fix if anyone can help please. thanks I am assuming that the fluid overflow is from your radiator? Probably a cooling problem, as the radiator also has the cooling burden of the tranny. Is the coolant temp rising? I had a 95 sr5 as well and had problems with tranny overheating at heavy load or high speed. I installed an external transmission cooler ($80 bucks installed at a local hitch shop) and replaced tranny filter and fluids and my probs went away. Have you performed routine maintenance on the cooling system and the transmission. May be time for filter / fluid change on the tranny and a flush and new thermostat on the cooling system. Bad thing is the thermostat isn't easy to get to like on many vehicles. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
