toyota injectors #23209-46031lalojamesliz 06-24-2005, 11:34 AM i just got some fuel injectors toyota part #23209-46031 and they go in the turbo kit for camry's and are the injectors for supras 93-98. they are rated at 305cc well for now they sit my safe but what happens if i just throw them in my 04 tacoma (its the 3.4L) im just curious. 2 are new in the box and the other four have less than a thousand miles and are these the ones for the fuel upgrade to aid the supercharger problem? thanks in advance Brian R. 06-24-2005, 01:56 PM i just got some fuel injectors toyota part #23209-46031 and they go in the turbo kit for camry's and are the injectors for supras 93-98. they are rated at 305cc well for now they sit my safe but what happens if i just throw them in my 04 tacoma (its the 3.4L) im just curious. 2 are new in the box and the other four have less than a thousand miles and are these the ones for the fuel upgrade to aid the supercharger problem? thanks in advance Yes, those are the high-flow injectors you need for the s/c. http://www.gadgetonline.com/fuel.htm#Injector%20Upgrade From the above link: Before you install them make sure the coil resistance is 13.8 ohms. Toyota uses injectors with different coil resistance and you must use high impedance injectors of about 13.8 ohms or you may smoke your ECU. You will also have to use some type of injector driver or controller. http://www.splitsec.com/ lalojamesliz 06-25-2005, 07:53 AM so are these any use for me without the supercharger? if not ill hold on to them until i get the supercharger, if yes..... lets experiment:) p.s. i just want more power..... like everyone else Brian R. 06-26-2005, 11:15 PM Not sure, but it sounds like you need a different fuel management unit with or without a S/C. lalojamesliz 06-27-2005, 01:22 AM does anyone know what a supercharger should cost at wholesale? i know a lady at my job and she told me she could get me anything at my toyoya dealer at wholesale price because her husband is the finance manager there. i want to know that way ill know if she tells me the true price not her price. lalojamesliz 07-02-2005, 01:12 PM ok one more thing are the 23250-46031 injectors the same/ are they good to supercharge my tacoma? see the thing is i bought these off ebay and the auction said they were 23209-46031 but i got them and they have 23250-46031 on the side.is this a problem? should i do something about it? thanks guys Brian R. 07-03-2005, 11:24 PM Call Toyota parts near you and ask. Maybe they can look up the application from the part number. If it fits the same application, you are probably good. If they don't fit the same application as the other part number, then you better try to get your money back. Automotive Network, Inc., Copyright ©2012
