Loss of Comprssion in #4 Cylinder600RR Racer 06-23-2005, 06:35 PM OK..my mechanic has taken the head off...machined it and still have a loss of compression in the #4 cylinder...has this happened to any of you? 600RR Racer 06-23-2005, 06:36 PM Sorry...forgot to mention it's a 1999 Dodge Ram 1500. Before the #4 cylinder went I heard a lot of pinging sounds coming from the engine. fredjacksonsan 06-27-2005, 09:46 AM Was any other work done to it? If he machined the head, great. You could have a bad set of rings in that cylinder. How many miles on the truck? weare4himinmex 10-02-2005, 11:24 PM You need to to a leak down test on the #4 cly..Did your mechanic check the piston good before putting head back on? could have burnt a small hole in the piston ..the ping noise is actually chewing away at a piston every time it pings. Dave Automotive Network, Inc., Copyright ©2012
