quarterpanel adjustment?pete44 06-23-2005, 03:54 PM Have a '94 Cherokee Sport and a '94 Grand Cherokee Laredo with the same problem...The front quarter panel catches/rubs against edge of front door when opening...any easy fix/adjustment to remedy this? Thanks,Pete44 chrisewers 06-23-2005, 08:57 PM check door hinges not overly worn (grap door when open and try to lift) if lots of play you should change hinge pins first. Also check fender has not moved due to accident damage. My manual does noy say much about adjustment, my 1995 grand cherokee has lots of room driver and pass side so find this a bit confusing. Automotive Network, Inc., Copyright ©2012
