Probs fixed but 2
JimR
06-21-2005, 02:53 PM
i have fixed all of my probs except 2 and 1 new.
my brake light is on but all brakes work as they should so i dont know y it is on; any ideas?
i still dont know y my trans leaked. it stoped but i want to know y. it only leaked when the car was lifted on the driver's side over night, so any ideas?
And the new on i found a black wire in the trunk cut and wraped in tape. it is about the size of amp wiring but IT IS NOT an amp wire. it looks like it ran too the fuel pump shut off switch be i dont know. i can't fined where the wire runs because it runs under behind the back seat panaling. and im not ready to tare out the back seat yet. so it you have any ideas on that I would like to know.
Thanks
shawnwilliams
06-21-2005, 10:25 PM
brake light sound like a bad wire, or you might just need to change the light bulb.
For the tranny maybe one of you gaskets are leaking.
As for the wire try to find were the other half goes that might be the wire for you rear brake light. Thats probably the ground and it wont let the power out and it just staying on.
JimR
06-22-2005, 09:31 AM
the wire is that big? thx ill have to find where it is supost to conect to
dangstangs
06-24-2005, 11:02 PM
if both lights are on look for the brake switch under the dash at the brake pedal bar it could be at fault.
if only one you got a short, your getting current to the bulb somewhere causing it to light.
JimR
06-25-2005, 11:56 AM
yes both lights are on but the ABS light has a good reson for y it is on. the Jacka*s who owned this car before me cut the sencor's wires in the front for some reason. you can tell that they where cut because the rubber is not riped it was sliced buy a clean sharp blade like a box cutter. but ill look into the brake thx.
