p0441 code. Any Answers yet?johnholl 06-21-2005, 12:05 PM Is it a problem with the valve itself, or is it a related problem which sets this MIL flag Brian R. 06-23-2005, 09:55 AM Could be either. Check to see if your car falls under the following extension of warranty: http://www.epa.gov/compliance/resources/cases/civil/caa/toyota.html Affected Auto list: http://www.epa.gov/compliance/resources/cases/civil/caa/toyota_aff_veh.pdf anos_l 07-28-2005, 04:41 PM Could be either. Check to see if your car falls under the following extension of warranty: http://www.epa.gov/compliance/resources/cases/civil/caa/toyota.html Affected Auto list: http://www.epa.gov/compliance/resources/cases/civil/caa/toyota_aff_veh.pdf check : first - vapor pressure sensor(check the conector with engine on 4.5- 5 V, after pressure switching valve the price for sensor - 180 -200 $ CAD valve price is 124$ but, check the vacuum hose cracks, holed, blocked, or disconeced after you can change the sensor or valve ( I hade the same thing, i changed the sensor the light is gone, after you chenge samthing you mast diconect the bateri Automotive Network, Inc., Copyright ©2012
