Middle Console Removal Help between seats 99 blazer 2 door[RIT]IVIr_Evil 06-20-2005, 08:15 PM I was wondering how I remove the middle console between the 2 front seats in a 2 door 4wd 99 blazer.. I tried searching for similar threads.. but found none. any help will be appreciated.. thanks -Tom rlith 06-21-2005, 07:41 AM IVIr_Evil']I was wondering how I remove the middle console between the 2 front seats in a 2 door 4wd 99 blazer.. I tried searching for similar threads.. but found none. any help will be appreciated.. thanks -Tom Up front it should be just clips, lift up the arm rest for the centyer compartment, remove the 2 phillips head screws, remove the center compartment, you will see a bracket in there w/ 4 10mm nuts, remove the outer ones. Pull console. If you have the wide front console (cups holder mounted left to right instead of front to back) lift up the liner and there will be a 10mm nut in the hole under it. [RIT]IVIr_Evil 06-21-2005, 08:07 AM Thanks rlith.. I'll check it out after work today.. My plan is to run all my amp kit wires under the carpet in that area to the back of the blazer.. is that a good idea you think? Because i didn't want to takethe back panals all the way off... did that befor and I didn't want to do it again.. cause got some squeaks from doing it before.. rlith 06-21-2005, 08:15 AM Shouldn't be a prob... I run stuff throught there... Automotive Network, Inc., Copyright ©2012
