Trans Prob
JimR
06-20-2005, 02:56 PM
ok i jacked up my probe to do the driverside brakes, i left it up all night, i come outside to find alot of trans fluid on the ground on the pasenger side. anyreasos?
1996 GT MTX
Aaron Lele
06-23-2005, 04:24 PM
1996 GT MTX
Jim, i see that you most likely had to fill up your probe with transmission fluid. I need to change mine so how much do you put in and where exactly are the drain and fill plugs located? I have a 93 probe, so i thought that you could help me since we have the same model.
JimR
06-24-2005, 02:19 PM
i have not filled it yet. im still trying to find out y it leaked. i should be filling it this weekend so ill let you know.
the drain plug is located directly under neath the tranny. it big so it will stick out. i dont know where the fill plug is yet.
do you have a MTX or ATX trans.? if you have and auto the fill plug is realy the dip stick tube.
performanceprobe
07-01-2005, 02:35 AM
its possible bad seal on the pass.side axel,as far as refilling,you refill at the dipstick tube.
VlaDeMaN
07-13-2005, 01:22 AM
the fill bolt is actually on the side of the tranny very close to the drain hole. its about the same sized bolt too. 2.8 quarts is sufficient.
