96 Neon Computer Pin-out Map?
palindromelol
06-19-2005, 06:53 PM
I'm looking for a pin-out map for the engine control modual. I want to attach a diagnostics buffer and I can't find the detail of the pin-outs and the voltage/current limits input / out put states.
Anyone have knowledge where I may find them?
das2123
06-19-2005, 08:58 PM
Try the FSM (factory service manual)
palindromelol
06-19-2005, 10:51 PM
The Factory Service manual will answer just about any question in this forum. So, if everyone had a Factory Service Manual there would be no reason for this forum. The only less useful suggestion would be to call the Chrysler design team in Michigan.
If I had a factory service manual I would not have posted. I take it you do not either or if you do you are unwilling to disclose the information. Thanks.
das2123
06-19-2005, 11:00 PM
I have the FSM for my 99, don't know if it is the same for a 96, since the 95's and 96's had alot of differences than the 97-99's. Besides you asked if anyone had any KNOWLEDGE where you may find them. Answer being a FSM!
palindromelol
06-19-2005, 11:18 PM
Let us make a blanket presumption, since it is not obvious to everyone, that 1) most answers to questions related to 96 neons are available in the 96 FSM or in the minds of the authors of the 96 FS manuals 2) the first place to look is the FSM, 3) that is a question is posted a substantive answer is desired 4) that if a question is posted, the answer is not already known, 5) context to one sentence in a question, may be found in another sentence, ergo the wonderful meaning of paragraph and the beauty of the english language.
palindromelol
06-20-2005, 12:29 AM
96 Neon Wire Color and connections
Wire Stripe Termination
Violet None Idle Speed Control Motor
Grey Red Idle Speed Control Motor
Brown White Idle Speed Control Motor
Yellow Black Idle Speed Control Motor
LTGreen Red Speed Control Servo
Tan Red Speed Control Servo
Red LTGreen Speed Control Servo Switch
Yellow Red Stop Lamp/Speed Control Servo Switch
White Pink Stop Lamp/Speed Control Servo Switch
White Orange Speedometer and Vehicle Speed Sensor
Orange None Speedometer and Vehicle Speed Sensor
Orange None Crankshaft Position Sensor
Grey Black Crankshaft Position Sensor
Orange None Camshaft Position Sensor
Tan Yellow Camshaft Position Sensor
Violet LTGreen Battery Temperature Sensor
Tan White Down Stream Heated O2 Sensor
White None Power Steering Pressure Switch
Black DKGreen Up Stream Heated O2 Sensor
Black Tan Ground
Black White Ground
Black Grey Ignition Coil Pack
DKBlue Tan Ignition Coil Pack
Black Tan Ground
DKGreen None Generator
Brown None/Orange A/C High Pressure Switch
Orange DKBlue Throttle Position Sensor
Violet White Throttle Position Sensor
DKGreen Red IAT/MAP Sensor
Black Red IAT/MAP Sensor
Black LtGreen Knock Sensor
Tan Black Charging Lamp Instrument Cluster
Grey LTBlue Tachometer
Black Pink Charging Lamp Instrument Cluster
Grey Yellow ERG Transducer Solenoid
DKBlue White ERG Transducer Solenoid and Conn
White LYGreen Vapor Cannistor Leak Detector
Orange None Vapor Cannistor Leak Detector
Red White Power Dist Center and OBD II
Pink Black Duty Cycle EVAP/Purge Solenoid
Orange Black Torque Converter Clutch Solenoid
Brown None Power Dist Center to (Fuel Pump relay)
DKBlue None Fuel Tank Modual and Gage
DKBlue Yellow Power Dist Center to (Auto S/D relay)
DKGreen Orange Power Dist Center to (Auto S/D relay)
White DKBlue Fuel Injector 1
Tan None Fuel Injector 2
Yellow White Fuel Injector 3
LTBlue Brown Fuel Injector 4
Black LTBlue Common to Several Sensors
Tan DKBlue Engine Coolant Sensor (or Tan/Black)
Brown Yellow Ignition Switch and Power Dist Center
DKBlue Orange A/C Compressor Clutch Relay in PDC
DKBlue Pink Radiator Fan in PDC
Pink None AntiLock Brake Controller and OBD II
LTGreen None OBD II
